remove space center pod power store
Thread begun 9/07/2013 7:21 am by luisc257726 | Last modified 9/09/2013 11:32 am by luisc257726 | 463 views | 1 replies |
luisc257726
How do I remove the space in the center pod so it lines up with the other 2? Also when I edit the test I cannot change the color of the text in the editor. No matter what color I choose it defaults to grey.
I was able to remove the space, but I am highlighting the text and selecting the color and it stays Grey. I must be doing something wrong, but it seems pretty simple.
to remove the space, you need to edit the index.dwt.php file for the selected theme.
go to the webassist/themes folder, in that folder is a subfolder for each theme, select the sub folder for the theme you are using.
in that theme subfolder open the Templetes folder and open the index.dwt.php file.
in the template file, remove the P tag around the middle pod content:
change:
<p class="morespace"><?php echo WA_getCMSContent($database_PowerStoreConnection$PowerStoreConnection,"Middle Pod""Content"); ?></p>
to change the font color of the middle pod text, in the admin menu select Content.
Edit the Middle Pod -> Content content area.
Select all the text, then use the font color tool to select the color you with to use. The text needs to be highlighted before you make the color selection.
