PayPal Express Checkout option
Thread begun 9/05/2013 9:55 am by eric284736 | Last modified 9/05/2013 1:49 pm by eric284736 | 24469 views | 17 replies |
eric284736
Hi Jason,
I need to setup PayPal Express as another option for payment on this site and when I originally ran the checkout wizard I think PayPal was added.
On the test page (checkout2.php) the PayPal button is near the bottom, but when I click on it I am redirected to the pp_checkout_failure.php page.
On that page I have error reporting in place and it see the following errors:
Notice: Undefined variable: eCart1 in /home/aerialda/public_html/pp_checkout_failure.php on line 9
Fatal error: Call to a member function IsEmpty() on a non-object in /home/aerialda/public_html/pp_checkout_failure.php on line 9
What I need to accomplish overall is to have PayPal as an option to make payment and then have it return to the site with the order success and send a universal email receipt with the link to download the purchase. That is how it is currently setup, but the payment method is using PayPal Pro to process the payments on the site. That function will stay in place.
thx
Eric
the error is happening because the the following code at lines 14 - 20
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1
->GetContent();
needs to be at line 8
to determine why the transaction is failing, add the following code in the body:
<?php @session_start(); var_dump($_SESSION); ?>
this will dump the session contents and will include the full response from paypal.
eric284736
Okay this is the response:
array(8) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["eCart1_Items"]=> string(199) "13|WAECART|Beginning Aerial Fabric - Digital Download|WAECART||WAECART||WAECART|0|WAECART|1|WAECART|32.95|WAECART|6|WAECART|0|WAECART|32.95|WAECART|1 Beginning Aerial Fabric - Digital Download (13)" ["WAEC_ContinueRedirect"]=> string(47) "/shop-digital-detail.php?ItemID=13&ItemCateID=6" ["eCart_PPECO_System"]=> string(2) "US" ["PayPal_ECO_Token"]=> string(0) "" ["ECO_Auth_Request"]=> string(1622) "info@aerialdancing.comGCZNDZWDKMUM2DXMAmaGca1e39ivv-6Kp1Es3HEF1HDmAku8oYl2Yb7ylUzMrIkIcJOqPPFJ63.0http://aerialdancing.com/pp_confirm.phphttp://aerialdancing.com/pp_cancel.phpSoleBillingAuthorization
32.9532.95Beginning Aerial Fabric - Digital Download32.95113Authorization" ["ECO_Auth_Result"]=> string(2060) "2013-09-05T17:39:52ZFailurebce6292e28ec7Security errorSecurity header is not valid10002Error63.07560199" }
Warning: require_once(WA_eCart/Adv_CO_Scripts/PP_ECO_Authorize_PHP.php): failed to open stream: No such file or directory in /home/aerialda/public_html/pp_checkout_failure.php on line 24
Fatal error: require_once(): Failed opening required 'WA_eCart/Adv_CO_Scripts/PP_ECO_Authorize_PHP.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/aerialda/public_html/pp_checkout_failure.php on line 24
so the response from paypal is:
this means that the API Credentials entered for Express checkout are not correct
eric284736
The Express credentials are different than the Pro credentials, correct?
No, they are the same.
eric284736
Duh! I had the wrong user name.
Okay so I set the return URL after PayPal processes and that would be the pp_confirm.php page or the pp_checkout_success.php page?
I need it to send the UE receipt with the download link like it would when an order is processed thru the local checkout.
thx
Eric
return url should be the pp_confirm.php page.
add the UE Server behavior to that page also
If you use the checkout wizard to create the pages using paypal pro, it will set all this up for you
eric284736
Got it, Thanks Jason!!
eric284736
Okay, the pp_confirm.php is in place and I get this error:
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/aerialda/public_html/pp_confirm.php:6) in /home/aerialda/public_html/pp_confirm.php on line 8
Fatal error: Call to undefined function WA_PP_ECO_GetValue() in /home/aerialda/public_html/pp_confirm.php on line 226
