email shows "on behalf of" need to alter php ini file
Thread begun 9/04/2013 8:45 am by sam308940 | Last modified 9/06/2013 9:46 am by Jason Byrnes | 11324 views | 9 replies |
sam308940
i have used universal email to send a "signup" email confirmation. when its sent the email arrives with the HOSTS email address on bealf of mine.. IE username@hostname.com on behalf of myemail@mydomain.com
i also went through the checkout wizard of ecart, and that setup an email confirmation, and that email arrives showing the same issue, with the username@hostname.com on behalf of myemail@mydomain.com.
i contacted my host about this. (i have never experienced this at any other hosting company). the response i got back was this:
the fastest method is going to be a custom php.ini for this user with sendmail_from = defined with a suitable address
so my question is this, should i be alarmed by this? it seems odd to me because i have used your scripts on at least 6 different hosting platforms and never run into this.
and 2nd, anyone have any idea what line i need to add to the php ini file? or anyone know of another solution to fix this?
You can set the sendmail_from using the following code at line 1 of any page you add Universal Email to.
<?php ini_set('sendmail_from', 'user@example.com'); ?>
sam308940
well i tried the above and it didnt solve the issue. the emails come through exactly the same as before. i even renamed the page to test it and ensure there was no refresh issue.
any other idea?
is this an issue with my host that is bad? im a bit confused as to why i have this issue with them and never before on any other host.
sam
The may not allow the send mail setting to be changed through ini set.
if it's not working, you will need to do it in a php.ini file.
if you need help with that, you should contact the host.
different hosts have different setups. It is quite common to run into an issue with settings on one host but not on another.
sam308940
jason
after chatting with tech support and a few tests, theres nothing that i can do to over-ride the sendmail_from. theres nothing they can do either. apparently the settings are on the server in a way that it cant be overriden.
so i went to the pear option. at first i got the file not found errors, but after playing around with pear path, i finally got rid of it, and now im getting this error: Fatal error: Class 'Net_SMTP' not found in /home/reblove/php/Mail/smtp.php on line 349
so i dug around in cpanel, and i found where where the pear installations are. i had it re-install both the MAIL, net_smtp and some other NET package too. i couldnt get the errorr to resolve.
any idea how to troubleshoot this one?
in the universal email option to send mail (not the pear option, just the regular mail option) is it possible to have it authenticate and send through the server? or does this method NOT use authentication at all?
that error:
indicates a problem with the Pear Installation. You will need to work with the host to correct the problem, it is a server problem, not a code issue.
The standard Mail function does not support authentication, only the Pear mail object supports authentication.
sam308940
ok the host accepted that it was an issue, and they resolved it.
so i no longer get the above error.
the form appears to submit, moving on to the confirmation page.
however, no email is sent.
i have the FROM as an email address of the domain on the server.
and the TO is my email address.
i searched the forum for others with this issue, but couldnt find anything giving me any clues. can you help me out, i need guidance on where to look to troubleshoot.
thanks again and again
sam
on the tank you page, add the following code near the bottom before the closing </body> tag:
<?php @session_start(); var_dump($_SESSION); ?>
this will write the session contents including whether sending the email was successful or not.
if the status is successful the problem is on the SMTP Server
sam308940
hi
si im getting a failure message:
array(8) { ["waue_emailcomplete_1_Status"]=> string(7) "Failure" ["waue_emailcomplete_1_Index"]=> int(1) ["waue_emailcomplete_1_From"]=> string(36) "HireNurses.com " ["waue_emailcomplete_1_To"]=> string(17) "sam@myemailadderss.com" ["waue_emailcomplete_1_Subject"]=> string(24) "HireNurses.com Community" ["waue_emailcomplete_1_Body"]=> string(154) "
Thank You For your Registration!" ["waue_emailcomplete_1_Header"]=> string(25) "X-Mailer=HireNurses.com; " ["waue_emailcomplete_1_Log"]=> string(108) "Sending To: sam@myemailadderss.com... Validation failed for: HireNurses.com - Failure
so i went through and changed a few things.
i changed the mail server from mail.domainname.com to the server ip.
(in my outlook account settings to connect it i have mail.domainname.com as the incoming and outgoing server. so im pretty sure thats right).
i also tried port 25 and port 587, as well as 465
all failures.
does the above help us narrow anything down?
well, the from address:
HireNurses.com
is only the domain, it does not include the user account. The from address must be a full email address:
person@HireNurses.com
I'm betting that in the authentication settings, you also don't include the full email address. The authentication must be a full email address for the domain and include the password
The SMTP server is refusing the username and password you entered, so you should check with the HOST to determine what username and password should be used.
