if, else statement not sure why it's not working
Thread begun 9/03/2013 8:23 am by tdhkfinkel424121 | Last modified 9/03/2013 11:38 am by Jason Byrnes | 2938 views | 3 replies |
tdhkfinkel424121
I'm trying to break my problem down to smaller bit and I thought an if..else statement (or in this case if..if.. because I keep getting an error with if..else in my dreamweaver program) would help but it's not working...
<script language="javascript">
function processSubTotalA()
var quantity = parseInt(document.MarinaServices.txtLOA.value);
var unitPrice = parseFloat(document.MarinaServices.txtMoorPrice.value);
var subTotalA = unitPrice * quantity;
if(quantity <30);
(isFlatRate = true);
(flatRate = 1599);
(flatRate = unitPrice);
(flateRate = subTotalA);
if(quantity >30);
(isPerFoot = true);
(unitPrice = 55);
(perFoot = unitPrice);
(subTotalA = unitPrice * quantity);
document.MarinaServices.txtServiceASubTotal.value = serviceASubTotal.toFixed(2);
function calculateTaxAmount(price, tax)
var amount = price * tax / 100;
return amount;
function processMoor()
var MoorTotal;
var subTotalB = parseFloat(document.MarinaServices.txtServiceASubTotal.value);
var subTotalB = subTotalA;
var taxRate = parseFloat(document.MarinaServices.txtTaxRate.value);
var taxAmount = calculateTaxAmount(serviceBSubTotal, taxRate);
var moorTotal = serviceBSubTotal + taxAmount;
document.MarinaServices.txtServiceBSubTotal.value = serviceBSubTotal.toFixed(2);
document.MarinaServices.txtTaxAmount.value = taxAmount.toFixed(2);
document.MarinaServices.txtMoorTotal.value = moorTotal.toFixed(2);
</script>
function processServiceASubTotal()
var unitPrice = parseFloat(document.MarinaServices.txtMoorPrice.value.value);
if(quantity <30);
(flatRate = 1599);
if(quantity >30);
(isPerFoot = true);
(unitPrice = 55);
document.MarinaServices.txtMoorPrice.value = moorPrice.toFixed(2);
var amount = eval(price * tax / 100);
return amount;
function processMoorTotal()
var SubTotalA;
var subTotalA = parseFloat(document.MarinaServices.txtServiceASubTotal.value);
var subTotalB = eval(subTotalA);
var taxAmount = calculateTaxAmount(subTotalB, taxRate);
var moorTotal = eval(subTotalB + taxAmount);
</script>
</head>
<body>
<table width="800" border="0" cellspacing="0" cellpadding="0">
<div id="wrap">
<form action="" id="MarinaServices" name="MarinaServices" onsubmit="return false,">
<tr>
<th scope="col"><table width="100%" border="0">
<tr>
<td align="left" nowrap="nowrap"><label for="SUMMER_Moor_LOA_Boat" class="sublabel"> <strong>Summer Mooring:</strong><br />
May 1- Oct.31</label></td>
<td align="left"> <span class="style59">*</span>
<input id="txtLOA" input="input" name="txtLOA" type="text" class="formTextfield_XSmall" value="<?php echo((isset($_GET["invalid"])?ValidatedField("MarinaServices","txtLOA"):"")); ?>" size="4" tabindex="33" onblur="hideServerError('txtLOA_ServerError');" />
Ft. LOA</td>
<td><span class="style59">*</span> $
<input id="txtMoorPrice" input="input" name="txtMoorPrice" type="text" class="formTextfield_XSmall" value="<?php echo((isset($_GET["invalid"])?ValidatedField("MarinaServices","txtMoorPrice"):"")); ?>" size="11" tabindex="34" onblur="hideServerError('txtMoorPrice_ServerError');" />
/ft</td>
<td><input name="btnMoor" type="button" onclick="processMoor()" value="Calc." tabindex="35" /></td>
<td>Sub Total $
<input type="text" name="txtServiceASubTotal" class="formTextfield_Small" size="8" value="0.00" tabindex="36" /></td>
</tr>
</table>
<tr>
<td>&nbsp;</td>
<td colspan="5"><input name="btnCalculate" type="button" onclick="processMoor()" value="Calc. Tax/Total" tabindex="37" /></td>
</tr>
<tr>
<td colspan="2" >Sub Total:$
<input name="txtServiceBSubTotal" type="text" class="formTextfield_Small" value="0.00" size="8" tabindex="38" /></td>
<td>Tax Rate</td>
<td><input name="txtTaxRate" type="text" class="formTextfield_XSmall" value="6.25" size="5" tabindex="39" />
%</td>
<td>Tax Amount:$
<input name="txtTaxAmount" type="text" class="formTextfield_Small" value="0.00" size="8" tabindex="40" /></td>
<td>Mooring Total: $
<input name="txtMoorTotal" type="text" class="formTextfield_Small" value="0.00" size="8" tabindex="41" /></td>
</tr>
</table>
<tr> </tr>
</table>
</form>
</div>
</th>
</tr>
</table>
</script>
</body>
</html>
I'm only working on the top section of this form.
And yes I did request one on one help session, but if you could look at this in the mean time I would be greatful.
I need more details.
What is it you are trying to do?
What specific code is it on this page that is not working?
What is it supposed to do?
What does it do instead?
tdhkfinkel424121
Oop Sorry
Hi Jason,
Sorry I guess I forgot the explanation...
What I'm working on is creating an 'if...,else' statement for the MoorPrice.
If the value entered in the LOA text box is less than 30 then the MoorPrice & subtotal should be 1599
If the value entered in the LOA text box is more than (or equal to) 30 then the MoorPrice should be 55 and the calculation for the subtotal should be
subTotalA = unitPrice(MoorPrice) * quantity(LOA)
The rest of the calculations of that part of the form stay as is.
Instead of doing the above it does nothing, no calculations at all.
i'm still pretty confused as the calc button in the top line calls the processMoor() function and that function has a number of syntax issues, the worst of which is this line:
using a variable that does not exist:
serviceBSubTotal
there is subTotalB, but no serviceBSubTotal.
in other areas< you have code for the if statement:
if(quantity <30);
(flatRate = 1599);
that is wrong for a number of reasons:
a) no semi colon after the if statement
b) the open bracket should be on the same line as the if:
if(quantity <30) {
c) You redefine twice
(flatRate = 1599);
d) no parens are needed around setting flat rate:
flatRate = 1599;
the format of the if else statement should be:
if(quantity <30) {
do something
} else {
do something else
