PowerCMS destroys PowerGallery code
Thread begun 8/29/2013 12:09 pm by Rune Brynestad | Last modified 8/29/2013 1:42 pm by Rune Brynestad | 2487 views | 4 replies |
Rune Brynestad
The latest version of Power CMS text editor destroys the add to site code for Power Gallery. The gallery works on the webpage, but when I go back in and look at the coding, the code I put in for the gallery is gone.
The source code
<h2>Look at my pictures</h2>
<p>
<input type="hidden" name="powergallery" id="1" theme="light" value="/home/1/s/sjaforvikaren/www/gallery/galleries/ribbon_lightbox_powerstore/index.php" />
</p>
Is changed to
<p>&nbsp;</p>
when I open the editor text again.
I have followed the recipe in this thread
http://www.webassist.com/forums/posts.php?id=25899
If you need to troubleshoot directly, see private message.
Regards
Rune
you need to change the toolbar to the Full toolbar which includes form elements.
using the default toolbar, form elements are strips since they are not a part of the toolbar.
Rune Brynestad
Yes, but now the code changes from
to
<input name="powergallery" type="hidden" value="/home/1/s/sjaforvikaren/www/gallery/galleries/ribbon_lightbox_powerstore/index.php" />
The id and theme attributes are missing when I open the editor again
Regards
Rune
I updated the webassist/ckeditor/config.js file to correct the problem.
this is actually corrected in Design Extender 1.1.5 also
Rune Brynestad
Works perfect now.
I see that I need to upgrade my webassist extensions to the latest versions.
Thanks again for looking into this.
Regards
Rune
