check if email exists and login
Thread begun 8/29/2013 5:41 am by bentulk | Last modified 8/29/2013 7:04 am by bentulk | 3075 views | 2 replies |
bentulk
I'm trying to design a process for users to either 'login' or 'create an account'.
1. Form where user enters email address.
2. email address is looked up in database to see if it exists.
3. If it exists, user then prompted to enter password. (or if remember password checked previously, it is entered.)
4. If email does not exist, user prompted to check it, try again, then insert record if does not exist. New user then prompted to create a password.
5. Move onto custom checkout forms.
Though I see a number of ways of acheiveing this, to save time, I want to start using the best approach and get it right first time (as if!).
Could you advise me on whether the following is a good approach or whether you know of a better option:
-Use security assist to create login page/s.
-Use spry validation on login page to check email address in database. Create a session variable with email address.
-Use hide/show regions.
Thanks,
Ben
This will require hand coding to accomplish.
you would need to use AJAX to query the database after the email address is entered, and then show the correct login or registration form based on the result.
bentulk
Thanks Jason,
I'll go to your custom coding form and fill in right now.
Ben
