PowerStore how to re enter admin
Thread begun 8/29/2013 3:42 am by bob.lee357763 | Last modified 9/13/2013 7:20 am by Jason Byrnes | 3200 views | 9 replies |
bob.lee357763
PowerStore_Files unzipped into localhost/Modular.
Everything was working fine until close, database, connections all good. Products added etc. Closed session for dinner now cannot reenter. Have tried localhost/Modular/PowerStores_Files/admin, no good. Advise please
do you mean to say that the address:
is returning a 404 error? or what exactly do you men by:
in what way is it no good?
if it gives a 404 error, double check the file system for the correct folder name.
for example, using windows, and XAMPP, the localhost folder is ussually at:
c:\XAMPP\htdocs
go to that folder to look in the Modular folder and find the folder name that was used for the power store installation.
bob.lee357763
c:\XAMPP\htdocs
Problem solved. I created new folder and cut and pasted all PowerStore Files into new folder. Now when i run localhost/newname/admin everything works as it should
bob.lee357763
Originally Said By: bob.lee357763
Jason it must be my cryptic communication. The Modular Website was created in xamp/htdocs/Modular/PowerStore_Files. As stated everything worked as it should, database built, connections established and the PowerStore administration ran which let me add product and related details etc. Now I cannot re enter the administration page. From your support page the path to reenter the admin page would in my case be localhost/Modular/PowerStores_Files/admin. PDF of Index of site and home site are attached. I am not getting an error. I am not able to re enter admin page
see pm
bob.lee357763
PowerStore Connection
Connection error
That error means that the connection details for the MySQL Server in the Connections/PowerStoreConnection.php file are not correct.
contact you host for details on the correct MySQ Server name to enter and the correct Username, password and database name to use for making the connection.
Wa there a new question you had?
This thread has reappeared on my open list, but I don't see a new question?
If you have a new question, it would be best to start a new thread, or add the new question as a reply at the end of the thread.
bob.lee357763
Popwerstore Admin
Hi Jason. I have run into a problem. The store is built and online with inventory added. All was going well until the next step which was to update and tweek everything. Unfortunately I cannot log into the admin again. I read through the forum replies and used that info to look at my database. My info was on line 94. The user name and password are as recorded however I still cannot enter admin. Look forward to your advice. Regards bob Lee
