Errors on email receipt in eCart
Thread begun 8/28/2013 11:36 am by mrsam5266 | Last modified 8/28/2013 2:10 pm by mrsam5266 | 2304 views | 6 replies |
mrsam5266
I need to pass some session variable amounts to be printed on the bottom of the email receipt.
When I submit the order I get the following errors.
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/n/u/t/nutradine/html/aquadine/webassist/email/waue_pp_confirm_6.php:268) in /home/content/n/u/t/nutradine/html/aquadine/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/n/u/t/nutradine/html/aquadine/webassist/email/waue_pp_confirm_6.php:268) in /home/content/n/u/t/nutradine/html/aquadine/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/n/u/t/nutradine/html/aquadine/webassist/email/waue_pp_confirm_6.php:268) in /home/content/n/u/t/nutradine/html/aquadine/pp_confirm.php on line 513
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/n/u/t/nutradine/html/aquadine/webassist/email/waue_pp_confirm_6.php:268) in /home/content/n/u/t/nutradine/html/aquadine/pp_confirm.php on line 513
Warning: Cannot modify header information - headers already sent by (output started at /home/content/n/u/t/nutradine/html/aquadine/webassist/email/waue_pp_confirm_6.php:268) in /home/content/n/u/t/nutradine/html/aquadine/pp_confirm.php on line 643
I am attaching a copy of the email template as it is currently.
The session variables are all set to the proper values.
send the webassist/email/waue_pp_confirm_6 file so i can take a look at the code.
mrsam5266
here you go
starting at line 266, you have some cusotm code that uses echo statements:
echo "Blend 110: ";
etc....
dont use echo statements, instead concatenate the string to the mail body string:
$MailBody = $MailBody = "Blend 110: ";
mrsam5266
If I directly edit waue_pp_confirm_6.php I have attached a copy as it is after the edit as waue_pp_confirm_6-original.php
If I then check things in the UEmail behavior on the pp_comfig.php page I get this pp_confirm_WAUE_HTML_WA_Universal_Email_6-in edit pp_config.php that I have attached also. All the code that I appended gets set outside the php tags in the package.
And the waue_pp_confirm_6.php file has been changed and now shows syntax errors.
I'm confused :-))
one or the other, edit the code directly or set the mail body in the UE wizard, you should not be going back and forth.
mrsam5266
OK didn''t realize it would do that. Direct editing it is then.
Thanks Jason
