checkout.php have states drop down trigger another dropdown
Thread begun 8/28/2013 4:57 am by watercolor346374 | Last modified 8/29/2013 7:06 am by Jason Byrnes | 1144 views | 1 replies |
watercolor346374
Good morning,
When a customer chooses Florida as their state, I want another dropdown to appear with the counties. Then customer has to choose their county for tax purposes. Stuck at how to have the ID for florida trigger the hidden dropdown. Tried show if and did not have any luck.
Thank you,
K
this takes hand coding to accomplish and is not supported.
as an example you could set the style for the counties select list to use display none
style="display:none"
then use an onchange event on the state select list to change that if FL is selected:
onchange="if(this[selectedIndex].value =='FL') { document.getElementById('countiesList').style.display = 'block'; }
