Access to payment gateways
Thread begun 8/27/2013 10:43 am by tren297782 | Last modified 8/27/2013 2:13 pm by tren297782 | 3820 views | 10 replies |
tren297782
I can not find how to make my store go live. I believe its in sandbox mode, but for the life of me I can not make it "live". There is no obvious control panel that I can change, where should I look?
Tren
this depends on the gateway you selected when running the checkout wizard, what gateway did you select? PayPal Pro? PayPal; Standard? other?
tren297782
to be honest I do not remember... it was a small flurry of activity, but I am pretty sure I selected other. Is there a way to rerun the wizard without loosing all my file changes and store?
when you checkout, Do yo go to the payment gateway or enter the credit card details on your own server?
if you enter the credit card details on the checkout page, then you are using a local checkout method.
on the confirm page, open the server behaviors panel, and locate the local checkout server behavior to make changes to the checkout settings.
tren297782
All i get is an error page:
www.zetkayak.com
the error url is http://zetkayak.com/checkout.php?valid=false
looks like you added validation to the checkout / confirm page and the validation is not passing
tren297782
so how do I change that?
I can not get CP access to any of the payment or registration info
The validation server behavior should be added to the confirm page.
on the confirm page, open the server behaviors panel and edit the Server Validation server behavior to make changes to the validation settings.
tren297782
I have no access to the confirm page from the admin side this is all I see.
My Apologies, i thought you where asking about making changes in eCart, i did not realize this was for Power Store. Guess I need to read more thoroughly.
It looks like you are logged in using a standard admin account, you need to login using the Super Admin account that you created during the Power Store install
Using the Super Admin account, there will be a settings menu item in the menu bar which will allow you to change the gateway settings.
