Unable to browse images
Whenever I edit any page and try to browse the server to add a previously uploaded image I get a server error 500 page. (screenshot attached)
Is this a permissions error or something?
Thanks in advance.
Thanks in advance.
the 500 error message is very vague, it really just means an error occurred, to determine the cause of the error, error reporting needs to be enabled.
edit the webassist/kfm/index page and add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
What version of PHP is your server running?
The File manager of HTML Editor requires PHP 5.2 or greater.
That error usually happens if the server is using an older PHP version.
The server is running PHP Version 5.2.17
