The Dreamweaver is not connecting to the database on a private server I have with GoDaddy. In the videos and messages I have seen, it seems that if I don’t have a test server validated that it won’t connect to the primary database. I tried to point the t
The Dreamweaver is not connecting to the database on a private server I have with GoDaddy. In the videos and messages I have seen, it seems that if I don’t have a test server validated that it won’t connect to the primary database. I tried to point the test server to the primary database, but that did not work. So I tried to add MySQL locally and to use that as the test database. Yes, I installed workbench with MySQL. The error I get when I test the connection for both the test and the primary database is “An unidentifed error has occurred, a very generic message. Yes, the ftp connection is working fine and the credentials for the database are correct. When I put the database php page to the server, it works fine. But I should be able to connecting through dreamweaver when I create and work on webpages.
