checkout/add to cart/continue buttons longer on testing hosting...but works on my localhost on my PC..so confused..
Thread begun 8/26/2013 9:01 pm by Christopher West | Last modified 8/27/2013 8:08 am by Christopher West | 1574 views | 2 replies |
checkout/add to cart/continue buttons no longer work on testing hosting...but works on my localhost on my PC
Hmm Jason, a little puzzled by this...as i dont believe I have changed the code so much that its done something to the ecart buttons on the product and cart pages...whats odd it all works fine on my localhost but when i uploaded it to a live testing hosting the buttons no longer work.
for example if you use the below link to go directly to the product page then click "add to cart" the page just reloads (the item does get added to the cart though as the link in the header will display quality in cart that you can click on.
http://www.webstarweb.co.uk/projects/dinky/product.php?Product=Double Print Bookmark
In addition if you were to use the Shopping Cart link in the header if you were to click on the checkout button on the main content area (not the checkout button in the header) then the page will refresh adding a ? after paypal-cart.php in the address bar.
I am wondering if its anything to do with the fact that I have uploaded the website under /projects/dinky rather than being in the root (perhaps thats why it works on my localhost and not the live hosting server)?
All the code is the same as the current live website...but on my live testing hosting I have changed the code so that the URL in the address bar uses the actual product names rather then the productID...plus I have added a form in the menu and some ther tweaks that shouldnt interfere with the ecart side of things.
Chris
Resolved....it was due to a carriage return that created an empty line of space.
it is probably a php error occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
Hey Jason, As I mention at the bottom of my post, it was resolved....Basically after some troubleshooting, Ray found out that it was to do with a carriage return between some include files at the very top of my page which the redirect didnt like spacing.
Chris
