Error 500 previewing loca
Thread begun 8/26/2013 9:05 am by jlowery | Last modified 8/26/2013 10:03 am by Jason Byrnes | 2502 views | 5 replies |
jlowery
I'm attempting to preview a page via localhost to which I've added 3 ATC buttons. I get a 500 server error when previewing through Chrome and in Firebug, this:
"NetworkError: 500 Internal Server Error - http://localhost/Horizon/buy-batteries.php"
Other pages in the site preview fine with localhost. How do I debug?
Thanks - Joe
try adding the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
jlowery
Thanks. I get this error:
Fatal error: Call to a member function GetContent() on a non-object in /Applications/MAMP/htdocs/Horizon/buy-batteries.php on line 11
Here's my initial code up to line 11:
error_reporting(E_ALL);
//WA eCart Include
require_once("WA_eCart/horizon_PHP.php");
<?php require_once('Connections/horizon.php'); ?>
$horizon->GetContent();
Next?
the Cart object and connection are using the same name.
you need to use unique names for the cart object and connection, they cannot be named the same.
jlowery
Got it working. Thanks, Jason!
you're welcome.
