HTML editor preview not showing styles
Thread begun 8/25/2013 1:56 pm by bryan107833 | Last modified 10/07/2013 5:52 pm by stephen287384 | 2097 views | 5 replies |
bryan107833
I have added an external style sheet (I believe) to the HTML editor. Did get some errors about shared files etc. My problem now is that the styles are not being previewed in the html editor. It does show that the style in the style dropdown list but no preview. This is a problem since my client will have no idea of the actual formating.
bryan107833
Ahh, found it ...again..all set. Thanks.
Glad to hear you found the problem.
in case others run into the same issue, can you share the solution you found?
stephen287384
Yes how did you get it working?
reggie356178
Anyone know how to get this working? Please post. Thanks.
stephen287384
I did get this working in the end, you need to add each style to a javascript file you create "stylelist1.js" and make sure to add the link to the css stylesheet in the <head> of the admin update, insert pages. Jason wrote thread on how to do this.
http://www.webassist.com/forums/showthread.php?t=24060
