Dynamic Images from Data Source - Dreamweaver CC
Has anybody figured out how to add dynamic images fusing a data source in Dreamweaver CC?
I dont follow your question.
you can use a recordset to return the image names, and use the recordset repeat region to loop through the records.
in the image source, use the image filename column:
<img src="image/path/<?php echo $row_recordsetName['columnName']; ?>" />Hi Jason, I know how to write the code, I used to find the insert image > Data Source wizard useful as a starting point, and wondered if there was a way to get this back or if there was an extension that could do the same.
Im not following what you mean, can you provide more details?
have you installed the Deprecated Server Behaviors extension:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
Ive already installed the depreciated extension.
You used to be able to go to Insert > Image and then instead of selecting a file, you could select a data source. The option to choose a data source isnt there anymore.
With the deprecated server behaviors panel extension installed, i have the data sources option in the iInsert -> Image dialog box, try reinstalling it.
If it is still missing, you will need to contact Adobe.
Guess I will be contacting Adobe then!
Same here im starting to hate adobe this cc is crap sorry about pointing it out here
Hay Daryl just ran into this problem i noticed jason in using a mac and you have the same operating system as me it looks because the pictures are different.
Im on hold with adobe as we speak.
Did you ever figure this out?
Looks like Adobe removed this on the Windows version, but not on the Mac version.
For Windows, you will need to use the bindings panel and code view to add the dynamic binding, you asked this in another thread also, see my reply there:
http://www.webassist.com/forums/posts.php?pid=174568
