Why do I have to remove so much garbage from my login pages?
Thread begun 8/21/2013 5:42 pm by bjgarner241692 | Last modified 8/26/2013 8:49 am by bjgarner241692 | 4824 views | 6 replies |
bjgarner241692
Like the Data Assist pages your revamp of Security Assist has destroyed a perfectly good extension.
Where do you get off insisting that I implement a simple 4 cell table in CSS?
Why do you insist on implementing validation even though I do not select it in the GUI?
What right do you have to determine the complexity and length of my usernames and passwords?
Why would you create the username field as a 'password' field?
I am really quite incensed that you took so many HIGH QUALITY extensions and combined them into these 3 absolute monsters. They are bloated beyond anything reasonable and you have absolutely destroyed some of the elements which made Web Assist the standard that all others should strive for.
Every single time I use Data Assist or Security Assist tools since my last upgrade I am left absolutely furious with the wasted time that it entails.
I cannot even demand my money back because of the way you embedded so many extensions together into your 3 main pieces.
In spite of your absolutely fanatical level of support when your users encounter issues I am still left angry and disappointed by what you have done to these two elements of your product. In their previous iterations they were absolutely bullet proof. They were light weight and they installed flawlessly.
Many Customers requested a CSS Layout for the forms created by Security Assist.
The validation and element type settings can be controlled In the Field Settings section of the manage pages tab. If you want to create security assist pages that have no validation, remove all validation settings in the Field settings page, password fields will have required validation added, so use a text field for the password instead, you can always change it back after the pages are created.
In the field settings section, you can also change the password strength settings.
Also,edit the login and user update pages to uncheck the option to include captcha. Using these settings will create pages that have no validation, we aren't forcing any of these settings, they are easily changed in the wizard.
If you are not happy with the way the wizard creates the pages, you can always create them manually. The wizard does not do anything that cannot be done by adding the server behaviors.
Or if you don't like the forms created by the wizard, you can delete them from the page and create your own, just make sure to use the same element names.
bjgarner241692
It is impossible to remove all of the validation code using your Ui.
If I do not select validation for any element there should be no includes, scripts or divs related to validation on my page.
It is useless overhead.that causes errors.
Yes, the Spry Validation needs to be deleted manually.
If you use the steps I provided for creating pages that do not include validation, no validation code will be added.
bjgarner241692
I'm sorry, but your answer makes my point. Even if I do not select any validation, I still have to manually remove the Spry Validation components. PLUS I have have to take the extra step to set username to Text from Password which should never have been set that way in the first place and I have to change the Password field from Password to Text and then back again.
1. These extensions should save work, not create it.
2. Past versions worked as expected.
3. DataAssist pages have similar issues
If I have a date field in a form, your wizard decides without my input what format that date will take and arbitrarily inserts a data picker - and it calls the default DATE format in a MySQL database incorrect. If I want to keep your DatePicker, I have to at least change the validation which, since I did not choose to validate any field SHOULD NOT BE THERE IN THE FIRST PLACE!
I have worked in this industry for going on 20 years and I have to say I have never encountered another company that offers such incredible support for their products. You go above and beyond to help designers and it is greatly appreciated, but you have this one 100% wrong. You need to rework your UI for these products to give the simple, straightforward results you always have and save the bells and whistles for those who want them. I expect to have to add validation and formatting. I do not expect to have to remove them.
On the manage pages tab, If you edit the registration and login pages, you have the option to include captcha, if you uncheck that option, there is no need to manually remove the captcha validation.
I have logged a bug about the username field being added in the wizard as a password field, thanks for letting us know about that.
I will also log a feature request to have an option to generate the old style of pages.
bjgarner241692
Getting rid of the CAPTCHA is easy enough, but again, why add it if I don't request it.
I appreciate your logging the feature request. On that note, if CSS presentation is necessary to keep everything tight with the new extension that is acceptable to me although I greatly prefer tables for an admin page.
The bigger issue is adding elements that are not requested and in many cases, not needed. I added the suggestion to that section of your website this morning and within the hour, 2 people agreed, so I am not alone.
