Switch showing records showing limited number error
Thread began 8/21/2013 6:00 am by bentulk | Last modified 8/21/2013 9:44 am by bentulk | 503 views | 4 replies |
bentulk
I have made a master page, which allows a user to sort products by 3 fields. It also allows user to either 'show all' records, or 'show less' (40/page).
All appears to be working fine.
But when i add a 'Recordset Navigation Status' to the page, so it says 'records x to y of z', the 'show all' link on the page does not work. It just shows 40 records, as before.
I'm stumped on this. I have attached txt docs of the page in question. Hoping you might know what i'm doing wrong.
Thanks,
Ben
bentulk
Replied in private post
i changed the code for the recordset:
$query_limit_rsItems = sprintf("%s LIMIT %d, %d", $query_rsItems, $startRow_rsItems, $maxRows_rsItems);
$rsItems = mysql_query($query_limit_rsItems, $conn_dynamic) or die(mysql_error());
$row_rsItems = mysql_fetch_assoc($rsItems);
if (((isset($_GET["show"]))?$_GET["show"]:"") != "all") {
} else {
    $rsItems = mysql_query($query_rsItems, $conn_dynamic) or die(mysql_error());
and also changed the following code:
$all_rsItems = mysql_query($query_rsItems, $conn_dynamic);
  $totalRows_rsItems = mysql_num_rows($all_rsItems);
    if (((isset($_GET["show"]))?$_GET["show"]:"") == "all")  $maxRows_rsItems = $totalRows_rsItems;
bentulk
} else {
