Weird Result names under results page
Thread began 8/20/2013 8:20 pm by Freddy | Last modified 8/23/2013 7:36 am by Jason Byrnes | 698 views | 3 replies |
Freddy
I am having an issue with this site. I built the results page with Data Bridge in the "Inventory" Page of the site, where a list of boat results are displayed 10 records at a time.
The issue is encountered when the user clicks on the the arrows in order to see the next set of 10 records: The product names get strangely replaced with a string of code in front of it.
However, everything appears and loads fine on initial page load.
Link to the site in question is: http://tlmboats.com/inventory.php
Screen shots of the issue are also attached.
Any reason why this could be happening?
Please help
This was an issue with an older version of Data Bridge, it should be corrected in the recent update to 1.1.5.
If you send a copy of the page, i can show how to correct the code.
Freddy
Thanks Jason,
Attached is a copy of the file.
Let me know if you need additional files that go with it.
Thanks again.
edit line 460:
<div class="WADAResultTitle"><a href="boats_detail.php?BoatID=<?php echo($row_WADAboats['BoatID']); ?>" ><?php echo(isset($_GET["pageNum_WADAboats"])?"&pageNum_WADAboats=".intval($_GET["pageNum_WADAboats"]):""); ?>
<div class="WADAResultTitle"><a href="boats_detail.php?BoatID=<?php echo($row_WADAboats['BoatID']); ?><?php echo(isset($_GET["pageNum_WADAboats"])?"&pageNum_WADAboats=".intval($_GET["pageNum_WADAboats"]):""); ?>" >
