Error message
Thread begun 8/19/2013 11:45 am by Eric Goodman | Last modified 8/19/2013 1:19 pm by Jason Byrnes | 4091 views | 12 replies |
Eric Goodman
Error message
I did the install on a new site. Got to the final step after creating the user and password. This popped up and now cannot access the pages.
Warning: require_once(../images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/php5/lib/php') in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Eric Goodman
error message
Private Message
see pm:
Eric Goodman
error message
private
See PM
Eric Goodman
error message
Seeing this message:
Warning: require_once(../images/installed.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Eric Goodman
error message
Still not seeing the website... just the error
I see.
Looks like before you had added PCMS to the site, you had already created a Folder named "Images" using an upper case "I"
the PCMS files expect the folder to be named images using a lower case "i"
i changed:
require_once("../images/installed.php");
require_once("../Images/installed.php");
Eric Goodman
error message
Excellent. Last thing. All the images for the Power CMS are missing so there's little question marks everywhere. What folder do I need to upload?
