Side Navagation Bar
Thread begun 8/17/2009 6:38 am by tamyala164613 | Last modified 12/20/2009 6:53 pm by Andre.M | 8544 views | 15 replies |
tamyala164613
Side Navagation Bar
I have noticed that the side navigation list continues to grow as I enter my products. My database is huge and I don't want that list to go on forever. Is there a way to only show categories on the side navigation?
msjj000Beta Tester
Side Navigation Need
Hi WA,
Firstly - a great upgrade with the version 2 of PowerStore. The product variables were a great addition and are a help to reduce the number of products listed. I managed to get it localized and up and running for local country requirements utilizing all the same code changes from version one - keep it up!
I'd also like to utilize a cascading or collapsible/expandable side menu bar to only show categories and expand the selected category. Can you use the WA CSS menu writer to achieve this or alternatively can you assist with some php code? I've tried CSS menu writer in the past - simple to use; however it seems to muck up the predefined menu settings in place with the PowerStore. The site has grown from 7-10 categories to over 20 now and navigation the look and feel is getting messy withthe categories starting to stretch over a page.
Any advice would be great.
Thanks, Mark.
tamyala164613:
The side navigation menu is created in the CSSmenuWriter/intermediate.php file. You could edit lines 12 - 46:
<?php do { ?>
$catParam
= $row_ProductCategories['CategoryID'];
$catParam_ProductMenu
= "0";
if (isset(
$catParam)) {
$catParam_ProductMenu = (get_magic_quotes_gpc()) ? $catParam : addslashes($catParam);
mysql_select_db($database_localhost, $localhost);
$query_ProductMenu = sprintf("SELECT * FROM products WHERE ProductLive <> 0 AND COALESCE((SELECT GroupingID FROM productoptions WHERE productoptions.ProductID = products.ProductID LIMIT 1), ProductID) = ProductID AND ProductCategoryID = %s", GetSQLValueString($catParam_ProductMenu, "int"));
$ProductMenu = mysql_query($query_ProductMenu, $localhost) or die(mysql_error());
$row_ProductMenu = mysql_fetch_assoc($ProductMenu);
$totalRows_ProductMenu = mysql_num_rows($ProductMenu);
$WA_localRoot = "".$WAGLOBAL_localRoot. "";
$WA_remoteRoot = "".$WAGLOBAL_remoteRoot. "";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot = $WA_remoteRoot;
if ((
strpos($WA_curURL,strtolower($WA_localRoot)) !== false && strpos($WA_curURL,strtolower($WA_localRoot)) == 0) && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
$assumedRoot = $WA_localRoot;
      <a href="<?php echo($assumedRoot); ?>Products_Results.php?Search=true&CategoryID=<?php print $row_ProductCategories['CategoryID']; ?>"><h2><?php print $row_ProductCategories['CategoryName']; ?></h2></a>
<ul >
  <?php do { ?>
      <?php if ($totalRows_ProductMenu > 0) { // Show if recordset not empty ?>
  <li><span><a href="<?php echo($assumedRoot); ?>Products_Detail.php?ProductID=<?php echo $row_ProductMenu['ProductID']; ?>"><?php print $row_ProductMenu['ProductName']; ?></a></span></li>
  <?php } // Show if recordset not empty ?>
} while ($row_ProductMenu = mysql_fetch_assoc($ProductMenu)); ?></ul>
mysql_free_result
($ProductMenu);
} while ($row_ProductCategories = mysql_fetch_assoc($ProductCategories)); ?>
<?php do { ?>
$WA_localRoot
if ((
<?php } while ($row_ProductCategories = mysql_fetch_assoc($ProductCategories)); ?>
in order to only show the categories.
uberbean:
It will require hand coding to create a collapsible or expandable menu for the product categories. unfortunately, we cannot offer support for this.
jazzman247315378
tamyala, did you get the results you were expecting this fix? I am considering the same thing, but would like to hear from someone who has tried it.
msjj000Beta Tester
Yep - fixed - worked well
I tried it adn it worked well - thanks Jason.
I also aligned the titles to the left hand side. centred looks better with the inventory items but when they are taken away it looks messy.
UB
tamyala164613
Results
Originally Said By: jazzman247315378
Yes, this did work. Only the links to each category are shown. When you click the category link then the products for that category are shown.
mick106153
I tried the tweak as well and didn't like the results.
What I did instead was to play with the css to trim down the look and feel.
Still experimenting and looking forward to an accordion of some sort.
intuHorsesPowerStore/
Mick
We will try to address some of these issues in the next update to the powerstore. Thank you for the feedback.
denise234045
Similar Side Nav Question
I'm going to change the php to show the categories only as well - far too many products - but is there also a way to show only the categories, EXCEPT when you are in a specific category section and then list those products that are in the category a user is in?
So,
Category 1
Category 2
Category 3
product1
product 2
product 3
Category 4
You can do anything you want if you are familiar with php and aren't afraid to get your hands dirty. This isn't a configurable option in the globals.
