Quantity Rule?
Thread begun 8/16/2013 2:58 pm by elewis93815 | Last modified 9/04/2013 7:37 am by Jason Byrnes | 3116 views | 7 replies |
elewis93815
Quantity Rule?
I think I may have a minimum rule in place on an ordering page but I'm not seeing it. When a customer goes to order "babycakes" which are sold in dozens, it automatically adds 4 to the quantity which gives them and charges them for 4 dozen. I am probably missing something somewhere, however, I am not seeing the rule for this section (babycakes). I've attached the files for review.
elewis93815
I left a private message for you! Thanks!
on the order display page, you have the following code:
for ($n=0; $n<sizeof($cupcake1->Items); $n++)      {
    if ($cupcake1->Items[$n]->Cupcakes && $cupcake1->Items[$n]->Cupcakes > 0) {
      if ($cupcake1->Items[$n]->Cupcakes == 1 && $cupcake1->Items[$n]->Quantity < 4) $cupcake1->Items[$n]->Quantity = 4;
this forces a quantity of 4 if the Cupcake cart column is set to 1.
on the add to cart page, line 728 has the add to cart function for adding the baby cake items:
$cupcake1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemPlatterOptions, $ATC_itemTaxable,1,$ATC_itemPrice);
the second to last argument is setting the Cupcake column to 1, this is being processed on the cart display page and forcing the quantity to 4. I updated that to 0 to prevent the quantity from being changed.
elewis93815
Thank you very much Jason!
you're welcome.
elewis93815
Ok, this is weird. We resolved this 2 weeks ago, however, I got an email from our client saying that the quantity is again defaulting back to four when Babycakes are added to the cart?????? The babycakes are sold in dozens so when a customer orders babycakes, typically they order 1 dozen. The cart doesn't give them the option of ordering less than 4.
same problem as before.
line 730 is the add to cart function for the baby cakes:
the second to last argument is set to 1, it needs to be set to 0. using 1 forces the quantity to 4
