I can't seem to find the error in my code to get the form to work can you help me?
Thread began 8/16/2013 12:04 pm by tdhkfinkel424121 | Last modified 8/30/2013 6:10 am by Jason Byrnes | 2968 views | 21 replies |
tdhkfinkel424121
Hi
My form is returning the filled out version of the form instead of going to the thankyou page and emailing the results...
I've tried going over it several times and even put in 2 error finding codes-one of which keeps coming back with: ,36,79
I've gone to lines 36 & 79 and committed them out but it still comes back with the same error.
Help?
does not refer to line numbers in this instance.
it refers to the validations. the validation code on this page starts at line 13 and goes to line 105.
each validation has a number at the end that is used to refer to it.
line 70 is the line for validation 36:
$WAFV_Errors .= WAValidateDT(((isset($_POST["Insurance_EXP"]))?$_POST["Insurance_EXP"]:"") . "",true,"\b(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])-\d{4}\b","","",false,".*","","",true,36);
and line 91 is the line for validation 79:
$WAFV_Errors .= WAValidateDT(((isset($_POST["Date"]))?$_POST["Date"]:"") . "",true,"\b(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])-\d{4}\b","","",false,".*","","",true,79);
those are the 2 validations that are failing.
tdhkfinkel424121
Hi Jason,
Thanks...
It worked. I guess I misunderstood what the errors where.
Any easy one to fix...
tdhkfinkel424121
Hi Again-New Issue-HELP!!!!!!
Hi Jason,
I thought I had this working but I still can't get it to submit and I can't tell where I've messed up.
There's something with the Hull info... I keep getting an error message when I submit no matter what I do. And if I take out the requirement & spry the form wont do anything.
Help I need this done today!
all i can realy tell is that validation is failing.
to tell which validation is failing, we need to put the die statement back in:
if ($WAFV_Errors != "")  {
    die($WAFV_Errors);
    PostResult($WAFV_Redirect,$WAFV_Errors,"licenseform");
that will give us the comma separated list to tell which validation it is that is failing.
tdhkfinkel424121
Here's what I got
Hi Jason
this is what I got...
wavt_scripts_php.zip
tdhkfinkel424121
Hi Again..
I was re-thinking the problem and it all started after I tried to make the check box required with a spry.
So I'm going back to what I had-when I thanked you this morning and see if I can figure it out...
I'll let you know what happens
tdhkfinkel424121
Ok Having trouble with getting error message to come up on check box
Hi Jason,
My double backing worked! and so does the form.-Yeah!
But the error message on the check box doesn't come up when it's not checked...something's off with the spry maybe?
I don't know
See what you think
i think there are to many closing span tags.
change:
<span class="checkboxRequiredMsg">Please make a selection.</span></span> </span> </span> </span>I have read
<span class="checkboxRequiredMsg">Please make a selection.</span></span> </span> </span>I have read
