Logged in as directory owner di matches
Thread begun 8/16/2013 10:32 am by jo271221 | Last modified 8/18/2013 6:36 pm by jo271221 | 2663 views | 4 replies |
jo271221
I want to secure pages the VerifyListing.php so that only the owner can update the listing. I attempted to write the rule Logged in as Directory Id Matches however it is not allowing me to access the page even when I am logged in, it brings me to the log in page. I have attached the VerifyListing page, security assist pages, login and site access for CommunityHotline.com
Thank You!
you can t use a recordset value in a security assist access rule.
instead, edit the recordset on the verifiy listing page and add an additional where clause to check the ID column agains the directoryid session variable.
that way if they try to access a record that is not theres, it will return an empty recordset.
jo271221
Thank You.
I am unsure how to edit the recordset on the verifiy listing page and add an additional where clause to check the ID column against the directoryid session variable.
I think I am doing it somewhat as it passes the correct user id and content into the form. But I am not understanding how this works.
I am working on the attached accounts/verifyListingFW.php file
Line # 4
Line #59
$Paramid_WADAtbl_directorylistings = "-1";
if (isset($_GET['id'])) {
$Paramid_WADAtbl_directorylistings = $_GET['id'];
mysql_select_db($database_community, $community);
$query_WADAtbl_directorylistings = sprintf("SELECT id, businessname, firstname, lastname, email, city, fldstate, userid, userpassword, verifieddate FROM tbl_directorylistings WHERE id = %s", GetSQLValueString($Paramid_WADAtbl_directorylistings, "-1"));
$WADAtbl_directorylistings = mysql_query($query_WADAtbl_directorylistings, $community) or die(mysql_error());
$row_WADAtbl_directorylistings = mysql_fetch_assoc($WADAtbl_directorylistings);
$totalRows_WADAtbl_directorylistings = mysql_num_rows($WADAtbl_directorylistings);
edit the recordset using advanced view.
change the where clause:
WHERE id = Paramid
WHERE id = Paramid AND id = Paramdirectoryid
in the variables section, add a new variable as:
Type: integer
default Value: -1
Runtime Value: $_SESSION['directoryid']
you may need to add the following code at line 1 for the session to work:
<?php @session_start(); ?>
jo271221
recordset to only show to logged in user, show if
That worked great! Then I added a show if record exist to the form and a link to the log in page with a message if a record does not exist.
Thank You!
