str_replace
Thread begun 8/16/2013 6:08 am by Jamie | Last modified 8/17/2013 8:41 am by Jamie | 2809 views | 12 replies |
Jamie
str_replace
Hey Jason
Am using the following to rename plain English into a permalink:
$WA_fieldValuesStr = "".((isset($_POST["BlogTitle"]))?$_POST["BlogTitle"]:"")  ."" . $WA_AB_Split . "".((isset($_POST["BlogContent"]))?$_POST["BlogContent"]:"")  ."" . $WA_AB_Split . "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"])  ."" . $WA_AB_Split . "".((isset($_POST["BlogDate"]) && $_POST["BlogDate"]!="" )?date("Y-m-d h:i:s", strtotime(str_replace("/","-",$_POST["BlogDate"]))):"")  ."" . $WA_AB_Split . "".((isset($_POST["BlogTitle"]))?preg_replace('/[^0-9a-z(),]/i','-',str_replace(array("%","!","?","@","\-","/",".","\"","_","\'","*","#"),"",$_POST["BlogTitle"])):"")  ."" . $WA_AB_Split . "".((isset($_POST["Live"]))?$_POST["Live"]:"")  ."";
What am I doing wrong that would make the following Don't let bootstrapping lead to handcuffing make the URL www.domainname.com/blog/don---t-let-bootstrapping-lead-to-handcuffing (ie too many '-' in the word Dont)
Jamie
the relevant part of that line of code is:
i bet the probelm is being caused by the magic quotes setting being turned on which adds a forward slash in fron t of the single quote (or actually apostrophe) in "Don't" turning it to "Don\'t"
Try adding stripslashes():
((isset($_POST["BlogTitle"]))?preg_replace('/[^0-9a-z(),]/i','-',str_replace(array("%","!","?","@","\-","/",".","\"","_","\'","*","#"),"",stripslashes($_POST["BlogTitle"]))):"")
Jamie
thanks Jason but nope.. hasn'tworked...
edit. have noticed that the blog title that is being added is this Don’t let bootstrapping lead to handcuffing
The blog title is being added through aplain text form input so its not down to formatting...
Jamie
PM
thanks
Jamie
see PM
Jamie
see PM
copy the quote from your source into the array.
Jamie
sorry, not sure what you mean?
from the document that you are copying the Don't let bootstrapping lead to handcuffing string. Select the Right Single quote, copy that and paste it to the array in the string_replace function.
