Issue creating session variable
Thread begun 8/15/2013 9:31 am by hbibizadeh396670 | Last modified 8/15/2013 10:24 am by hbibizadeh396670 | 2940 views | 6 replies |
hbibizadeh396670
I am making a video rentals site, once a user makes a purchase the information is stored in a order details table.
When the user clicks the watch video, I use update server behaviour to add a 1 in the watch count field, this stops them from watching it again.
The script then takes them to a stream page, where I want a session to be filtered to display a video.
However, it is all working but the session.
I used the ecart create session, trigger any form post, and the value from a hidden field set to have the value of the video id from the recordset,
the issue is that the session is not being created when the user clicks the watch button even though it is all seemingly configured correctly.
What is going wrong?
No way of knowing that without seeing the code.
please send a copy of the pages.
hbibizadeh396670
Thanks for the help, I have added a file called moviecentre which is where the user see the videos they bought, and the stream which is where the video is played thanks again
try adding the following code at line 1 of the stream.php page:
<?php @session_start(); ?>
hbibizadeh396670
yep that did it...
thank you so much... best support ever!!!
php can loose "sight" of the browsing session.
on pages that you reference session variables, you should include the session start function, this forces php to look for the session.
hbibizadeh396670
Thank you, I will remember this for the future
