Data Bridge v1.1.4 for Dreamweaver CS6
Is it necessary to upgrade to Data Bridge v1.1.4 if one is using Dreamweaver CS6?
The list of fixes only seems applicable to DW CC.
That update is not essential for Dreamweaver CS6, but we wanted to make sure the same code base was being used across all platforms. It is up to you if you want to install it or not.
