Wizard will not create wa_randompassword.php
Thread begun 8/11/2013 5:49 pm by hbibizadeh396670 | Last modified 8/12/2013 1:15 pm by hbibizadeh396670 | 4566 views | 10 replies |
hbibizadeh396670
I followed the tutorial to create a Create a Double Opt In Registration System with Data Bridge
https://www.youtube.com/watch?feature=player_embedded&v=JBH2NpPUbaE#at=737
but now my page gives me this error... I also checked the folder and the file wa_randompassword.php has not been created?
Warning: require_once(../webassist/security_assist/wa_randompassword.php) [<a href='plugins/function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in C:\wamp\www\newsite\Authentication\Registration.php on line 2
Fatal error: require_once() [<a href='plugins/function.require'>function.require</a>]: Failed opening required '../webassist/security_assist/wa_randompassword.php' (include_path='.;C:\php\pear') in C:\wamp\www\newsite\Authentication\Registration.php on line 2
here is a copy of the wa_randompassword.php file to add to your site.
make sure that you have the most recent version of Data Bridge installed, if you have a previous version, uninstall it from the extension manager before installing the newer one.
hbibizadeh396670
I have a new issue.
I changed the access rule to account for an emailverify session = 1
but it did not seem to take affect... and now when login fails for any reason it will not return to the correct login page.... the URL is
UserRegistrationSystem/?failedLogin=1
when it should be
UserRegistrationSystem/Login?failedLogin=1
This is even though on the secure page window I have defined the page correctly.
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("EmailChecked")){
WA_Auth_RestrictAccess("Login.php");
Help Please
hbibizadeh396670
Sure
see PM
hbibizadeh396670
Sure
see pm
hbibizadeh396670
Ok
for the login page, the problem is the fialed redirect:
"failRedirect" => "../UserRegistrationSystem/?failedLogin=1",
this should be:
"failRedirect" => "../UserRegistrationSystem/Login.php?failedLogin=1",
For the forgot password [page, I am not able to reproduce.
I entererd the email address you provided and it redirected to the login page displaying the message:
Password information emailed, please check your inbox
It seams to be working.
