Multiple deletion of images
Thread begun 8/08/2013 5:46 pm by simmo515303621 | Last modified 8/27/2013 7:18 am by Jason Byrnes | 2882 views | 5 replies |
simmo515303621
Hi, Sorry if I have missed the post that helps with this issue..
I have created a gallery/album page - but I need to be able to multiple delete selected images... how can I do this.
I have attached my page
All of the images from an album are stored in a single directory... so you can use a recursive delete function to delete all of the files and folders in that directory...
Here is a function you can use to delete a directory and all of its contents:
function deleteDirectory($dir) {
if (!file_exists($dir)) return true;
if (!is_dir($dir) || is_link($dir)) return unlink($dir);
foreach (scandir($dir) as $item) {
if ($item == '.' || $item == '..') continue;
if (!deleteDirectory($dir . "/" . $item)) {
chmod($dir . "/" . $item, 0777);
deleteDirectory($dir . "/" . $item);
return rmdir($dir);
simmo515303621
hi Ray,
i dont need to actually delete all images, if you check out the script I sent - there is a checkbox that does a multiple record delete, i also need it to delete the images of the same name.. and those only.
to delete the images associated to the records being deleted in the multi record delete would take some hand coding to accomplish. respond back with a phone number of skype address, and we can work on this trough a screen sharing session.
simmo515303621
Hi Jason, great skype is simon.schroeder3
thanks
See PM
