Wish list
Thread begun 8/08/2013 2:59 am by tolushayoo193471 | Last modified 8/08/2013 6:06 pm by Ray Borduin | 2081 views | 6 replies |
tolushayoo193471
Wish list
Hi, Please is there tutorial on how to add wish list functionality to PowerStore 3 or how can I do it please.
You would have to own eCart to do it....
1) Create a new Shopping Cart called Wish List
2) Place "Add to Wish List" buttons on the product pages just like the add to cart buttons
3) You would have to require people to log in before seeing the "Add to Wish List" button
4) Create a view wish list page displaying your wish list cart
5) Create a database table to store the wish list items... it could contain just an autonumber column, the productid, userid, quantity, and the options (if you are using options)
6) Apply the Store Cart Details In Database server behavior on the wish list page so that the database stays current
7) Apply the Add to Cart from Database server behavior to repopulate the wish list cart on the login page
8) Place add to cart buttons in your wish list to transfer items from the wish list to the actual cart
Lots of steps... the final two are probably the most difficult, but very doable.
If you want help, this is something we can definitely help with in a premier support ticket.
tolushayoo193471
Wish list
Yes please, I will need help with the premier support ticket.
thanks
Premier support is based on the time spent and not the features we get to... we can help with just about anything and the amount of time it takes depends on how much you can do on your own in preparation before the meeting begins. Usually taking your best stab at it before the meeting so that we have to do as little as possible and just fill in the gaps is the most efficient way to get as much done as possible.
Officially we will work on as many issues as we can for the first half hour of the premier session. Then whatever issue we have started but haven't finished in the first half hour we will let spill over for up to one hour total. There is a hard stop at one hour unless you purchase an additional session... That is the hard line rules, but we are actually pretty generous when it comes to enforcing them.
Just go to the help section and fill out the premier request form and we will contact you to schedule the meeting.
tolushayoo193471
Ok, what about if I dont use up to 30 minutes to ask question, can the remaining minute be added to ironing the issue. Then since you are familar with wish list functionality, do you think we cant accomplish it with the 1hrs slots?
thanks
I think we will spend the full hour on the wish list, but should be able to get it done.
tolushayoo193471
ok thanks. I've filled the help form
