unstable confirm page, does't update order table
Thread begun 8/06/2013 1:43 am by Nutzo247 | Last modified 8/07/2013 11:22 am by Ray Borduin | 3384 views | 5 replies |
Nutzo247
based on the pervious post:
http://www.webassist.com/forums/posts.php?id=31929
the confirmation page works in passing the details to paypal but the order table doesn't always update the Order table address details
Nutzo247
I also looked at this posting and I adjusted the code
http://www.webassist.com/forums/posts.php?id=26861
but after the first attempt it works and then the order table problem comes back again.
You probably just have to clear the orderID session variable on the success page to force it to create a new record for the second transaction.
Nutzo247
If that was the case, even if I close the browser or test using a different browser on a different machine would generate a different session,I'm still not getting any joy.
Also other entries such as the order date and customer id would not be updated.
Also look at order ID 6 part of the database is updated
Nutzo247
I think I've found the problem, it's not the session order ID
it's to do you the order of the code blocks when the confirm page pulls the shipping address variables from the checkout page.
for example:
block like this (creating session variables from $_post data) must be declared first:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["eCartCheckoutForm_firstname"] = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"")  ."";
Then the order summary (code block starting with):
// WA eCart Store Cart Summary in Db
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $database01;
$WA_table = "tb_Orders";
$WA_redirectURL = "";
$WA_indexField = "intOrderID";
$WA_fieldNamesStr =
OK... glad you were able to figure it out. Let us know if you have any more questions or issues after the update.
