Multiple Timestamp fields
Thread begun 8/05/2013 8:54 am by iainmacdonald331081 | Last modified 8/06/2013 9:01 am by Ray Borduin | 1372 views | 2 replies |
iainmacdonald331081
This is probably slightly off topic, as its an SQL thing rather than a DA thing, but does anyone know of any workarounds to the limitation whereby you can only have one field in a table that timestamps the current date?
Basically would ideally have two fields - DateAdded and DateUpdated that can be set to populate automatically with the current date when a record is added or updated.
CraigRBeta Tester
I am pretty sure you can use a mysql stored procedure to help do this, but I have used a quick and dirty method in the past.
Keep the timestamp field for when the record is updated, with ON_UPDATE Current Timestamp as the field attribute.
Set the dateadded field as date time.
on the php page, set a php variable to the current time
<?php $dateandtime = date("Y-m-d H:i:s");?>
use the $dateandtime variable in your insert record server behavior
iainmacdonald331081
Thanks Craig - works perfectly!
