Lost all of my work
Thread begun 8/05/2013 7:09 am by zinlover320832 | Last modified 8/05/2013 4:58 pm by Ray Borduin | 2042 views | 3 replies |
zinlover320832
Lost all of my work
http://www.mmoliveoils.com/PowerStore453/PowerStore%20Files/admin/design.php
I opened up the admin and all of my edits are deleted. I had saved my work. Please help.
Thank you.
Whenever you save your design changes it creates a folder with the name you used in the webassist/themes directory. While you are editing the theme it saves the updates as webassist/themes/temp_editing folder.
You can look for the files there... if they really have been deleted, then you might contact your hosting provider who probably does daily backups and you can get a version from before they were deleted.
Once you recover your files then we can look into how they were deleted. It could be a permissions issue. Sometimes it can happen that the interface can't write files and that causes it to delete the old theme and then can't create the new one. To be safe you should store a backup of your theme in case it happens again. If you find steps to reproduce the problem then we can definitely get it fixed.
zinlover320832
I attached a screenshot of the files frank directed me to. The were all changed this am. What do I do? This is very frustrating. I have lost several hours of work. I had saved my work repeatedly.
Please help.
Thank you,
Stuart
It appears the temp_editing folder had read-only access and wasn't being overwritten. By manually deleting that folder via ftp things appear to be working again.
