Validation on decimal number
Thread begun 8/04/2013 10:53 am by massimo173451 | Last modified 8/06/2013 11:47 am by Ray Borduin | 1858 views | 3 replies |
massimo173451
Hi, when update the price (admin->product_update.php) using the decimal sepator (10,10) instead the dot (10.10) get the following error.Have you a suggestion for solve it???
You can change the number format in the spry property settings if you are using CS6 or below
In the CC version you may need to update the script manually:
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "currency", {format:"dot_comma"});
massimo173451
Thank you Ray for your reply, the code used is quite different from your code:
<label for="ProductPrice">Price: <font color="#FF0000">*</font></label>
<span id="sprytextfield4">
<input type="text" name="ProductPrice" id="ProductPrice" value="<?php echo(isset($_GET['valid'])?ValidatedField("ProductsUpdate","ProductPrice"):$row_WADAProducts['ProductPrice']) ?>" size="32" onBlur="if (document.getElementById('ProductPriceServerValidation')) document.getElementById('ProductPriceServerValidation').style.display='none';" />
<span class="textfieldRequiredMsg">Please enter the price of this product in your store.</span><span class="textfieldInvalidFormatMsg">Invalid format.</span></span>
if (ValidatedField('ProductsUpdate','ProductsUpdate')) {
if ((strpos((",".ValidatedField('ProductsUpdate','ProductsUpdate').","), "," . "4" . ",") !== false || "4" == "")) {
if (!(false)) {
<span class="textfieldServerError" id="ProductPriceServerValidation"> Please enter the price of this product in your store. </span>
Actually use:
OS WIN7 64
CS 5.5 Master Collection
Where I can change it ?
The script tag I referenced will be at the bottom of the page just before the </body> tag. You don't have to update anything in the html in the area you have referenced.
