Trying to populate form field with autocomplete from 2 different arrays
Thread begun 8/01/2013 8:14 am by stephen287384 | Last modified 8/05/2013 11:42 am by Ray Borduin | 2340 views | 3 replies |
stephen287384
I have a form with 2 fields "what" and "area". I have auto-complete working when there are 2 arrays, one for each field however i need the first field "what" to use data from 2 different arrays. Is this possible?
//This works
<form........
<input name="what" id="what" type="text" size="45" />
<input name="area" id="area" type="text" size="45" />
....../form>
<script>
var tags = [ <?php do { ?>"<?php echo $row_rsCategories['category']; ?>",<?php } while ($row_rsCategories = mysql_fetch_assoc($rsCategories)); ?> ];
$( "#what" ).autocomplete({
source: function( request, response ) {
var matcher = new RegExp( "^" + $.ui.autocomplete.escapeRegex( request.term ), "i" );
response( $.grep( tags, function( item ){
return matcher.test( item );
</script>
<script>
var tags3 = [ <?php do { ?>"<?php echo $row_rsDirectory['suburb']; ?>, <?php echo $row_rsDirectory['postcode']; ?> ",<?php } while ($row_rsDirectory = mysql_fetch_assoc($rsDirectory)); ?> ];
$( "#area" ).autocomplete({
response( $.grep( tags3, function( item ){
</script>
//This doesn't work
<form........
....../form>
<script>
</script>
<script>
var tags2 = [ <?php do { ?>"<?php echo $row_rsKeywords['keyword']; ?>",<?php } while ($row_rsKeywords = mysql_fetch_assoc($rsKeywords)); ?> ];
response( $.grep( tags2, function( item ){
</script>
<script>
</script>
I have tried changing form field id="what" to class="what" and changing $( "#what" ) to $( ".what" ) to no avail.
I have setup this script on jsfiddle to demonstrate http://jsfiddle.net/KtsXx
i dont think that will be posible, though you could edit the inital array to use both sources, so instead of using:
to populate the array, use:
var tags = [ <?php do { ?>"<?php echo $row_rsCategories['category']; ?>",<?php } while ($row_rsCategories = mysql_fetch_assoc($rsCategories)); ?><?php do { ?>"<?php echo $row_rsKeywords['keyword']; ?>",<?php } while ($row_rsKeywords = mysql_fetch_assoc($rsKeywords)); ?>];
stephen287384
Hi Jason, yes i had it working like that but not really what i was after. After thinking about what i'm trying to achieve, i might try a diferent approach.
We ended up getting this working in a Premier Support ticket. The solution was to combine both recordset results into an array. That way we could sort the array alphabetically and loop on it to populate the auto-complete.
