Security Assist - Admin Table
Thread begun 7/31/2013 2:07 am by Php | Last modified 7/31/2013 10:47 am by Php | 1107 views | 2 replies |
Php
Hi, I have an existing admin table in my database, however when I run security assist that table is not showing when I want to create the security assist pages. It says table to be created, but my table already exists. What can I do to solve this?
open the Database tab expand the connection and tables section, does the database tab list the table you want to use? If not, double check that the connection is connecting to the correct database.
Since you want to use your own table, in the security assist wizard set the application type to New From Blank, and select your table from the tables list.
the other application presets are based on the tables that will be created. using your own table, you need to start a new preset.
Php
I think there was an issue with the database connection, security assist is now showing the admin table thanks for your help.
