Help with a custom search
Thread begun 7/30/2013 8:28 am by iainmacdonald331081 | Last modified 8/01/2013 12:00 pm by iainmacdonald331081 | 5588 views | 16 replies |
iainmacdonald331081
I basically have a simple enough WA search working, and am trying to add second part to the search using a list of keywords.
Also have a search just using the keyword part working, but can't quite get both parts working in the same search form.
I don't think its far off though - think its juts a case of getting the SQL query right, and also the search comparison in the results page.
Assuming its not too complicated, any help with this much appreciated.
Details to follow below...
1) the code for the checkboxes:
echo "<input type=\"checkbox\" class=\"tickbox_".$row_type."\"";
if (in_array($keyword['ProfileID'],$profilekeywords)) { echo " checked"; }
echo " name=\"ckbox[".$keyword['ProfileID']."]\" id=\"ckbox[".$keyword['ProfileID']."]\">";
has a couple prolems:
a) The id does not need to be in the checkbox name.
b) you dont have a value.
try using:
echo " name=\"ckbox[]\" id=\"ckbox[]\" value=\"".$keyword['ProfileID']."\">";
2) on the bindings panel, click the plus button, select URL Variable, name the URL Variable:
ckbox
edit the data assist search behavior and add a new critiera.
set the criteria type to key word.
for the keyword or, use a coma followd by a space:
", " <- without quotes
for the keyword and enter:
AND
no spaces
For the value, click the lightning bolt icon and select the checkbox url variable. also add the following code at line 1 of the results page:
if($_SERVER["REQUEST_METHOD"] == "GET")     {
    foreach(
$_GET as $key => $val) {
        if(
is_array($_GET[$key])) $_GET[$key] = implode(", ", $_GET[$key]);
iainmacdonald331081
Thanks Jason.
I've made those changes, but wasn't sure about a couple of things.
For the ckbox criteria I made the Keyword AND value "AND" and the Keyword OR value ", "
But what should the separator and column have been? I just left them as they were, which was AND and RevisionID.
What I had before was only searching records which had at least one profile added, whereas now it is searching all records again, so that's definitely right.
But if you search on the checkboxes the results are looking a bit random.
I've attached the updated files.
the column should be the column you want to search on and the separator can be left as is.
iainmacdonald331081
Ah, yes. Changed the SQL query back to what I had tried before, i.e.:
SELECT DISTINCT revision.RevisionID, Project_Name FROM revision INNER JOIN revisionProfiles ON revision.RevisionID = revisionProfiles.RevisionID
And set the column to ProfileID.
Which from a couple of tests looks like its all working as I'd expect.
Thanks again for helping out with that.
iainmacdonald331081
Actually, not quite - its returning results where any of the checkboxes are a match, but should be where all of the checkboxes match.
For example, if you search using the checkboxes Road Atlas Ireland and GB / Ireland Town Plans it should only return results where both of those are a match,
The separator in the behaviour is AND, so not sure how to change that?
in the keyword criteria settings, change the OR Seperator to "OR" and the AND Seperator to ", "
iainmacdonald331081
Thanks Jason - thinking about it, there will probably be times when both would be useful, eg to search for all the transport related projects, so I'll probably use two search forms.
iainmacdonald331081
Only got round to making that change today but it didn't seem to work.
I've added links to the site for the search that returns with any checked, which works, and this one which should return results with all the checkboxes matching.
If you just search without entering anything, it returns all the records with at least one profile keyword.
If you search by checking one checkbox, it returns records with that keyword.
If you search by checking more than one checkbox, it draws a blank.
To test, I've created four test records with the keyword in brackets:
- Transport Interchange (Railway, Light Railway, Metro)
- Railway Scheme (Railway)
- Light Railway Scheme (Light Railway)
- Metro Scheme (Metro)
Checking all three checkboxes Railway, Light Railway and Metro in the checkboxes ANY search correctly returns all four records.
Checking all three checkboxes in the checkboxes ALL search should just return the Transport Interchange scheme, but draws a blank.
Have attached the updated files.
