Java error editing dynamic list menu ...Scripts:TagMenu.js: Invalid Array Length"
Thread begun 7/30/2013 6:55 am by john411474 | Last modified 7/30/2013 1:14 pm by john411474 | 3962 views | 5 replies |
john411474
At line 378 of file "MacOSX:Applications:AdobeDreamweaverCS5:Configuration:Shared:Control s:Scripts:TagMenu.js: Invalid Array Length"
DW 6.0
Getting this error message while trying to edit dynamic drop down menu.
Have deleted cache files to no avail
Hours go by, very frustrating
jrt
Can you provide some more details please.
what are the steps you are taking to reproduce this error?
What Extensions, including the version numbers are installed?
What is your OS?
can you attach a copy of the PHP page in a zip file so I can see the code.
john411474
OS: OSX 10.8.4
DW: CS6
Extensions: Data Bridge 1.1.3, Design Extender 1.1.4, Thomas Muck Simulated Nested Region 1.0.1
Been working with page for extended period of time without any errors
Has 3 WebAssist Dynamic Drop Downs. Error occurs on editting any of the list/menu .
john411474
More info
More info
the error is caused by using the name "size" for the size select list.
size is a javascript function name. javascript function names should be avoided for form element names.
john411474
fixed the error
thank you for the quick response
jrt
