Not receiving email (contact )
Thread begun 7/24/2013 4:09 am by Kumel | Last modified 9/23/2013 8:30 am by Jason Byrnes | 6913 views | 14 replies |
Kumel
I have created a contact form.. but now i m not receiving email.. i not able to understand the problem.
http://www.intralabsindia.com/contact.php
Required files are also attached..
Kumel
This is a very urgent enquiry as lots of visitors drop email.. I m not receiving email since 10days.. i just crossed check by filling myself. i didnt receive email at al.
Who is your host?
depending on your host you may need to set the SMTP Server address. Or you may need to set the From Address to be included as an extra parameter.
There are a couple of problem I see in your set up:
1) You have entered multiple to addresses and separated them by a coma. to enter multiple to addresses, you should click the To Button to enter the advanced To settings, and add each address individually.
2) on the attachments screen, you have added bindings for each of the form elements. the attachments section is to add file attachments, you should not be using the form bindings here.
Kumel
  Who is your host?
Kumel
Once again not able to receive the email.
I m facing this problem again. all of a sudden my emails are not getting received from http://www.webgen.in
Please have a look into asap.
Thank you.
you are using the same address for the from and to address, most hosts will not allow this, the SMTP Server will consider the email spam.
use a unique address for the from and the to settings.
To help troubleshoot, change the redirect page to a PHP page, then you can out put the session:
<?php @session_start(); var_dump($_SESSION); ?>
this session will contain a email status, if this is successful, then the email has been sent to the SMTP Server, you will need to work with the host to determine why the email is not being relayed in this case.
Kumel
Sorry about that... i understand i can not use same address for from and to
now regarding troubleshoot, which is the redirect page ? if its the [thank you] page then i did that page to php and inserted : <?php @session_start(); var_dump($_SESSION); ?> at top of the page..
even after that i m not getting any emails. and got this error on thank you page->
array(10) { ["waue_contact_1_Total"]=> int(0) ["waue_contact_1_Index"]=> int(0) ["waue_contact_1_Remaining"]=> int(0) ["waue_contact_1_Log"]=> string(47) "Sending To: kumel619@gmail.com... Success
" ["waue_contact_1_From"]=> string(17) "support@webgen.in" ["waue_contact_1_To"]=> string(18) "kumel619@gmail.com" ["waue_contact_1_Subject"]=> string(22) "Webgen.in Contact Form" ["waue_contact_1_Body"]=> string(6908) " --WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit Your Email Title Goes Here email subtitle area or directions can go here, below the title Form Submitted 9-14-2013 | 12:58 AM MST Name: Email: Phone: Comments: Submit: Submit Additional Notes: Lorem ipsum dolor sit amet, consectetur adipiscing elit. Donec eget tellus sed justo rhoncus posuere id sit amet arcu. Morbi pretium, enim faucibus facilisis hendrerit, elit. Morbi quis sodales ligula. Pellentesque elementum faucibus elementum. Sed rutrum dui in nisi dapibus molestie. Sed dictum ultricies viverra. In non urna vel nisi dictum tincidunt facilisis nec enim. In vitae lectus mauris. Mauris id sem non risus aliquam pretium at ac ipsum. Cras ac ultrices nisi. Cras ultricies ultricies bibendum. Duis vitae aliquam erat. Nullam justo augue, mattis quis ultricies in, posuere sed tortor. Aenean ornare orci nec felis semper vitae interdum velit ultrices. Ut auctor congue tellus in hendrerit. Aliquam et massa hendrerit leo sodales dapibus non ultricies mi. Morbi non tellus bibendum quam elementum bibendum sit amet vel metus. --WAMULTIBREAKWA Content-Type: text/html
Kumel
Alright i made the changes in centre.php the email page. so now i m receiving the emails. but not receiving any contents like name, email n etc.
Kumel
ok now i recreated the pages. now its working fine.. havent added any extra codes.. just normal.. please cross check and let me know if its fine ..
but i receive emails only sometimes. i dont know what is wrong.
thank you
It looks like it is set up correct to me, but that depends entirely on your host.
If the email comes through sometimes but not others, that is something on the SMTP Server, you would need to contact the host to have them look into the SMTP server error logs to determine why the email is not being relayed sometimes.
