Can you dynamically set the map.setZoom to show all recordset locations?
Thread begun 7/24/2013 2:38 am by Banksie | Last modified 7/25/2013 12:37 am by Banksie | 1756 views | 2 replies |
Banksie
I have a filter to find all stockists in a predefined postcode (zip code). Currently, regardless of the map.setZoom(); settings the map will generate centered on the first record in the recordset - not a real problem if there are only a very few records and each location is near the others.
Is there any way of setting the initial zoom to show all records found in the recordset - which could be 20+ based on the required, predefined, $_POST from the search criteria form?
Thanks in advance for your help. (You guys are, to date, the best by far at customer support)
Gary
Not really. there is not a way to tell what the required zoom will be based on the results that are returned.
there is not a way to determine what the area of the points is to set the zoom.
Banksie
Thanks Jason. I guessed as much but thought it was worth asking.
Great & speedy response from you - as usual. Much appreciated.
Gary
