keep form data on page refresh
Thread begun 7/23/2013 8:46 am by randyw2394710 | Last modified 7/24/2013 9:29 am by Jason Byrnes | 2131 views | 3 replies |
randyw2394710
on the insert update pages in power cms, ihave an overlay to add images, that works fine. the question is, when the add image is pressed the page reloads and clears all data previously entered. How do i keep original form data which the user entered, before it goes to data base.
content ref id
<input type="text" name="ContentRefID" id="ContentRefID" value="<?php echo((isset($_POST["ContentRefID"]))?$_POST["ContentRefID"]:"") ?>" class="validate['required','alphanum']" />
ck editor
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".((isset($_POST['ContentValue']))?$_POST['ContentValue']:"") ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "Blank (custom)";
$CKEditor_config["wa_preset_file"] = "(custom)";
$CKEditor_config["width"] = "98%";
$CKEditor_config["height"] = "300px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["docType"] = "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">";
$CKEditor_config["contentsLanguage"] = "";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["filebrowserBrowseUrl"] = "../webassist/kfm/index.php?uicolor=".urlencode(isset($CKEditor_config["uiColor"])?str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2";
$CKEditor_config["toolbar"] = array(
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','SpellChecker'),
array( 'Undo','Redo','-','Find','Replace','-'),
array( 'Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array('Bold','Italic')
$CKEditor_config["scayt_autoStartup"] = true;
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("ContentValue", $CKEditor_initialValue, $CKEditor_config);
This would require hand coding to accomplish, you would need to make sure the add image button also submits the other form data and save it to session variables.
we could help you configure this in a premiere support appointment.
randyw2394710
ive tride to set sessions to the insert form content refid and contvalue using the add-Image to start session but not working
also how do you clear session if user goes to another page
The image form is a different form, the initial form does not get submitted when the image upload form posts.
This is a custom coding implementation to accomplish, we could help with this in a premiere support appointment.
