change time zone
When Power gallery admin login box displays a gallery an error Function_date distort the display
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Chicago' for 'CDT/-5.0/DST' instead in /var/www/vhosts/4578.sandbox.i3dthemes.net/httpdocs/powergallery/admin_gallery/images/installed.png on line 2
Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Chicago' for 'CDT/-5.0/DST' instead in /var/www/vhosts/4578.sandbox.i3dthemes.net/httpdocs/powergallery/admin_gallery/images/installed.png on line 2
How do I fix it?
Peter Edwards
