I keep getting the following Warning when testing my form. I can't seem to figure out where the issue is. Can you help me with this?
Thread begun 7/22/2013 12:45 pm by tdhkfinkel424121 | Last modified 8/08/2013 10:06 am by Ray Borduin | 6191 views | 23 replies |
tdhkfinkel424121
When testing I get this-Warning: Cannot modify header information-headers already sent by (output started at/home/hingh3/public_html/webassist/email/templates/Block_HSM.php:39)in /home/hingh3/puplic_html/guest dockage 4.php on line 124.
Is the problem on the form or on the email response? And how do I fix this?
the problem is in the webassist/email/templates/Block_HSM.php file around line 39.
send a copy of that file so i can look at the code.
tdhkfinkel424121
File requested
Hi Jason,
Here's the file you requested-I still don't see where I went wrong. Hopefully you can figure it out.
tdhkfinkel424121
Info for trouble shooting
Hi Again,
Here's the info you requested....
Thanks again
in the guest dockage 4.php file, change:
include("webassist/email/templates/Block_HSM.php");
include("webassist/waue_guest%20dockage%204_1.php");
tdhkfinkel424121
Still getting warnings even after doing the change you suggested.
Hi Jason,
I tried this twice and even made sure that the bindings to the email were correct. Now I'm getting this warning:
Warning: include(webassist/waue_guest%20dockage%204_1.php) [function.include]: failed to open stream: No such file or directory in /home/hingh3/public_html/guest dockage 4.php on line 92
Warning: include() [function.include]: Failed opening 'webassist/waue_guest%20dockage%204_1.php' for inclusion (include_path='.:/usr/lib/php') in /home/hingh3/public_html/guest dockage 4.php on line 92
Warning: Cannot modify header information - headers already sent by (output started at /home/hingh3/public_html/guest dockage 4.php:92) in /home/hingh3/public_html/guest dockage 4.php on line 124
i bet the problem is caused by the space in your page name.
rename the page with out using spaces, then add the UE behavior again.
tdhkfinkel424121
It's still not working-Why?
Hi Jason,
I did what you suggested and then added a code so I could check for errors because the form was returning blank. I found an error on line 18 so I commented it out and tested it again. The form is still returning blank when I submit it. Where am I going wrong? Attached is the form.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
