preg_replace
Thread begun 7/22/2013 11:48 am by Jamie | Last modified 7/23/2013 8:47 am by Jamie | 4198 views | 11 replies |
Jamie
preg_replace
Hi Jason
Had a premier support session with Ray the other evening re the mod_rewrite stuff from the Poerstore webinar.
he helped set up the database to duplicate the title column entry to a permalink one and use pre_replace on it.
This is what I am using in the update record
<?php echo ((isset($_POST["NewsTitle"]))?preg_replace('/[^0-9a-z]/i','-',$_POST["NewsTitle"]):""); ?>
What that is doing is taking this sort of title
A sweet marketing idea!
and changing it to
A-sweet-marketing-idea-
Its taking any replaced characters (ie ! or . etc) and replacing them with -
How would I keep spaces replaced with a - but just remove the chars I dont want completely?
Jamie
use str_replace to remove the special characters before the preg_replace replaces the slashes:
for example:
<?php echo ((isset($_POST["NewsTitle"]))?preg_replace('/[^0-9a-z]/i','-',str_replace(array("!","?","@"),"",$_POST["NewsTitle"])):""); ?>
Jamie
Thanks Jason
Am seeming to not be able to include things like ", # and ' to be removed... do I need to wrap them in a certain way?
some character will need to be escaped, for example:
Jamie
like this?
((isset($_POST["NewsTitle"]))?preg_replace('/[^0-9a-z]/i','-',str_replace(array("\"","\^","\[","\(","\)","\*","\+","\?","\\","\'","\.","\-","\!"),"",$_POST["NewsTitle"])):"")
yes, that looks right.
Jamie
cheers
Jamie
Hey Jason
Why would the articles that have a ? in them fail to show?
http://www.ybg.org.uk/blog.php
The permalink is being changed in the _update page in the backend like this (not sure if that helps any):
?preg_replace('/[^0-9a-z()!?,]/i','-',str_replace(array("@","\-","/",".","\"","_","\'","*","#"),"",$_POST["BlogTitle"])):"")
A question mark in a URL tells the server that anything after it is a URL variable.
for example:
results.php?var1=foo&var2=bar
the question mark tells the server that the information after it is variables, in this case a URL variable named var1 that has a value of foo and another named var2 that has a value of bar.
Jamie
Ok, I get that... thanks
What if its part of a url friendly sentence, ie Credit control out of control? being converted to Credit-control-out-of-control? so that the resulting URL would be www.somedomain.com/blog/Credit-control-out-of-control?
If there is nothing after the ? .. why wouldnt that show?
Sorry, am not questioning you, am just looking to understand for my future ref.....
