Retaining Form Values & From Field Missing..
Thread begun 7/22/2013 4:37 am by Andrew Dodd - ADDIGITAL | Last modified 7/24/2013 2:16 am by Andrew Dodd - ADDIGITAL | 4465 views | 9 replies |
What's the best way to retain entered field values if the user, for example, gets the captcha wrong or some other validation fails?
I seem to remember somewhere, that if you set the initial value to the value of the form field, this would work.
Also, no matter how I try, I can NOT get the sender name/email address to display in the from field when the email arrives. I also want to send the sender a copy of the mail but the dynamic binding with the senders email address seems not to work.
URL is http://www.timperleymotors.co.uk/contactus.php
If I can get this sorted, I can get paid! Please help!! ;)
Andrew
CraigRBeta Tester
Couple of ways you can do it, you can store the field value as a session value, and use this as the default value, but what I prefer to do is add server side validation to the form, then using the server behaviors panel, you can set the field value to the validated form value, which will pre-populate the form when it is submitted incorrectly
Thanks Craig, will give that a try.
Do you know why the from field isn't being populated? Or anybody for that matter?
Cheers
Andrew
you are using an invalid name for the email address form element.
<input name="Email Address" type="text" required="required" id="femail" placeholder="Your Email Address" tabindex="2" autocomplete="on" value="" size="40">
Spaces are not valid for form element names. Form Elements names should conform to the following rules:
1) Only use Alpha numeric characters.
2) The only exception is the underscore
3) The first character of the name must be a letter.
Universal Email not sending now..
Hi Guys,
So now, I have a nicely validated form, that keeps it's values BUT:
When the form is submitted, the page loads itself again (with a blank page) instead of sending the mail and going to thankyou.php as it should.
Behaviour can be seen at http://www.timperleymotors.co.uk/contactus_new.php and the php page is attached.
I'm sure I'm missing something very simple and have been staring all afternoon. It's now 1027pm BST and I'm tired. Not sure whether it's the validations or Universal Emails that's causing the problem.
Also noticed that Firefox and Safari are throwing the following error out "The character encoding of the HTML document was not declared. The document will render with garbled text in some browser configurations if the document contains characters from outside the US-ASCII range. The character encoding of the page must be declared in the document or in the transfer protocol"
Could one of you kind folks have a look as another pair of eyes and help me out?
TIA
Andrew
CraigRBeta Tester
I can't see the attachment, (but if you have provided this, apologies, I have had a problem with not seeing attachments and not sure if WA have fixed this for me yet)
Hi Craig,
I'll try again. Many thanks for your help.
Andrew
CraigRBeta Tester
ok, got it, i will take a look when I am back at my desk.
in the meantime, try adding the following to line 1, it may help
error_reporting(E_ALL);
Hi Craig,
Thanks for that - that was my next step - but fortunately, I found it!
I changed the name of the Universal Email template from Blank to Blank Copy - but forgot to upload it! DOH
Told you I was tired :)
Thank you so much.
Andrew
This post has been deleted.
