Major Problem
Thread begun 7/21/2013 3:56 am by J7HNW | Last modified 7/23/2013 12:55 pm by Jason Byrnes | 2853 views | 6 replies |
J7HNW
Major Problem
I have recently bought Data bridge and want to simply set up my admin pages.
Every time I get part way through Dreamweaver Crashes
Have uninstalled and reinstalled databridge and design extender today ( 21st July ) and also deleted the winfilecache
Have also tried turning preview to off and closing Files and Bindings panels which I saw in another post but still no good
9 crashes this morning trying to set up simple Database admin forms. Please can you help
J7HNW
MORE PROBLEMS
Am upgrading to Dreamweaverr CC so will see if this fixes the issue
Have uninstalled Dreamweaver CS6 - cleared cache and in stalled Dreamweaver CC
Installed Databidge - tried to make the database pages ( started with just Search ) and again crashed !!
Help please
It works on search, details , insert , results - but crashes everytime when I try to build the update page
John
Are you using one of the Application presets? or selecting the New From Blank option?
If using a preset, are you selecting to have the table created fro you? or using your own table?
If using your own table, please send a dump of the table structure so i can try to reproduce.
Here are some things to try:
- Turn off the preview. Go to WebAssist -> Preferences. in the preview section, select the option to disable it.
- The underlying cause of the problem may be a memory leak in DW. restart the system to free all memory, then open DW and start the wizard.
- Before starting the wizard, close the files and server behaviors panels.
- after setting up one of the pages, pause for a moment or two before starting to set up the next one
J7HNW
Still not working
Hi Jason
Tried this and still not working - still crashing out of CC
Replies below .....
Are you using one of the Application presets? or selecting the New From Blank option? NEW FROM BLANK
If using a preset, are you selecting to have the table created fro you? or using your own table? CREATED MY OWN TABLE
If using your own table, please send a dump of the table structure so i can try to reproduce. ( ATTACHED )
- Turn off the preview. Go to WebAssist -> Preferences. in the preview section, select the option to disable it. DID THIS
DID ALL YOU SAID AND TOOK MY TIME - AND IT STILL CRASHES DREAMWEAVER CC EVERY TIME AT DIFFERENT INTERVALS
HOPE YOU CAN HELP
few things that strike me about the table definition:
1) I recommend using a naming convention that will prevent the possibility of using reserved words. the naming convention I like to use is to use <tableName><columnName>
for example:
motbookings:
motbookingID
motbookingName
motbookingAddress
etc...
2) you have the ID column set to mediumint, but the length is restricted to 9. that is nnot long enough for a medium int.
instead use a regular int and set the length to 11:
int(11)
3) you have 2 un needed keys set for the ID column:
UNIQUE KEY `ID` (`ID`),
KEY `ID_2` (`ID`)
by setting the ID column as a primary key, it already has a unique constraint, and it is already set as a key
4) the date column is set to varchar(500)
`Address` varchar(500) DEFAULT NULL,
if your server is using 5.0.3 or earlier, the maximum length for a varchar column is 250, to be able to use a larger length, double check the mysql server version.
J7HNW
All changed
Changed .... but
you have another thread where I was going to do a screen sharing session, I'll look into this issue at the same time.
