HTML editor not appearing on screen ... again...
Thread begun 7/19/2013 7:22 pm by sandy170299 | Last modified 7/22/2013 10:11 am by sandy170299 | 4343 views | 10 replies |
sandy170299
This is outside of the PowerCMS application, which is where I usually use the HTML Editor. This is on a page where I want to compose an email. I created a page and inserted the HTML editor into my page, and it's not visible when I browse it. Please see private email...
sandy170299
please see private message for URL.
CraigRBeta Tester
this thread may help...
http://www.webassist.com/forums/posts.php?id=31396
sandy170299
Thanks, Craig, but this did not work. All of the files are on the server.
sandy170299
See private message.
Originally Said By: sandy170299
sandy170299
Try it again, please.
sandy170299
wwwroot is the directory where the files are located. Yes, it's on a windows server.
This site is using CK Editor 3.1.3. Make sure you have the latest version of Data Bridge installed, we have recently released 1.1.4 which uses CK Editor 4.
uninstall the previous Data Bridge version, then install the newer version from your download center.
in the Webassist folder, rename the CKEditor folder, then edit the HTML editor instance to have the files recreated using the newer versions,
