Website Translation Using Google (or Microsoft) Translation API
Thread began 7/18/2013 9:38 pm by dc50093 | Last modified 7/19/2013 7:11 am by Jason Byrnes | 512 views | 1 replies |
dc50093
My client has a large, 10,000+ page, US based static website built on CSS Sculptor. They now require an international presence and have purchased all of the local domains... .fr, .es, etc. What is the best way to put a translation solution in place? They've some flexibility. It would not be an issue to convert the foreign sites from static into a Webassist dynamic site but is this the best way to go? Ideally, they are looking for a low maintenance solution that uses the Google (or Microsoft) translation API's, i.e., machine translation ((low cost). I realize this is not the best way to proceed from a search prospective... and human translation would be better, but that's what they want.
Thoughts, criticisms, and, most importantly, low cost solutions, are gratefully welcome.
for using one of the API's you mention, you would need to follow the instructions for that API for implementing it on your site, your questions are realy better addressed to the API Documentation than here.
Using data Bridge, you could have a separate databases for each domain that contains the language specific content, then use Dynamic Connections to connect to the appropriate domains based on the address. but that would not be using the API's you mention that you want to use.
