Got error, see below
Thread begun 7/17/2013 9:55 am by russb335115 | Last modified 7/18/2013 4:12 pm by russb335115 | 4758 views | 9 replies |
russb335115
Fatal error: require() [function.require]: Failed opening required 'Blank_2.php' (include_path='.:/usr/services/vux/lib/php') in /data/0/0/89/28/89517/user/90902/htdocs/chefologie/webassist/email/mailformatting_php.php on line 151
Can anyone help me?
make sure you have uploaded the entire webassist/email folder to the server.
russb335115
Here is the log from my upload
Started: 7/17/13 1:08 PM
webassist:email:mail_php.php - Put operation successful
webassist:email:mailformatting_php.php - Put operation successful
Connections - error occurred - Access denied. The file may not exist locally, may be open in another program, or there could be a local permission problem.
webassist:email:templates:Blank.php - Put operation successful
webassist:email:templates:Blank_2.php - Put operation successful
webassist:email:templates:Block.php - Put operation successful
webassist:email:templates:Block_2.php - Put operation successful
webassist:email:templates:Block_3.php - Put operation successful
webassist:email:waue_chefologie-family-order-form3_1.php - Put operation successful
webassist:email:waue_chefologie-family-order-form3_1_Progress_xml.php - Put operation successful
webassist:email:waue_chefologie-family-order-form_1.php - Put operation successful
There is only one error, not sure if that effects it or not.
russb335115
Just tried it again and it seemed to process, will have to check and make sure it was received but I think I might be good.
Thank you
russb335115
Hi Jason,
Okay the form looks like it is being sent to the designated email address but nothing is showing up.
Any ideas?
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
russb335115
Thanks Jason,
I will check on those things.
Do you know off hand what the requirements are for Network Solutions. As I mention in earlier talks, I will be working with 1and1 but this sit is all ready on NS
Here is the PHP that Universal Email created, it doesn't seem to have were the email form should go but I fill in the info in the interface:
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "chefologie website|WA|order@chefologie.com";
$MailSubject = "Wesbsite Order";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("","","","","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Additional Headers
//Attachment Entries
//BCC Entries
//CC Entries
$WA_MailObject = WAUE_AddCC($WA_MailObject,"russb@rgbdesigngroup.com");
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "";
$MailBody = $MailBody . (GetFromPage("templates/Blank_2.php"));
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody,"waue_chefologie-family-order-form3_1");
if (isset($GLOBALS["waue_chefologie-family-order-form3_1_Status"])) {
$MailLogBindings = new WAUE_Log_Bindings();
//Start Log Bindings
//End Log Bindings
$MailLogBindings->SuccessOrFailure->MailRef = "waue_chefologie-family-order-form3_1";
$MailLogBindings->Success->MailRef = "waue_chefologie-family-order-form3_1";
$MailLogBindings->Failure->MailRef = "waue_chefologie-family-order-form3_1";
$MailLogBindings->processLog(($GLOBALS["waue_chefologie-family-order-form3_1_Status"] == "Failure"));
$WA_MailObject = null;
I believe with network solution, the SMTP server address is:
smtp.<yourdomain>.com, but you should check with them.
also, i'm pretty sure they require the from address to be a valid address for your domain, and that the from address be included as an extra parameter for sending the email. you should double check with the host though.
russb335115
Hi Jason,
Well it went through but this is all that showed up in the eamil:
--WAMULTIBREAKWA--
Any thoughts?
russb335115
Hi Jason,
Never mind, everything is working great. Thank you for all your help.
Best regards
