how to log out user after 15 mins of inactivity? (destroy sessions)
I want to know if there is a built in feature (security assist) to after 15 mins of inactivity or do I need to hand code it?
That is not done through Security Assist, it is controlled with the Session Time out settings on the server.
see this post from the Webmaster world forums:
http://www.webmasterworld.com/forum88/12812.htm
So what I can see I will have to create a script or write in a php command to destroy the sessions at a set time?
You will need to edit the server settings in the PHP.ini file for the session time out.
